I’m looking for a few days but the i have a problem.
I’m running TVHeadEnd Server V4.1 on OSMC=
it work well with channel AAC 2.0
, ok with channel AC3
but the channel with EAC3 don’t work.
The mkv file with DTS or DD/AC3 are Ok.
With EAC3 channel i have black screen. The AVR is a pioneer VSX 824.
Where is the problem please
i have a log http://paste.osmc.io/nulewupuba.vhdl , at 22:26:00 it’s channel with EAC3 vs à channel with AC3 at 22:38:00
this is my setup of osmc:
result of tvservice -a
osmc@osmc:~$ tvservice -a
PCM supported: Max channels: 8, Max samplerate: 192kHz, Max samplesize 24 bits.
AC3 supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
MPEG1 supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
MP3 supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
MPEG2 supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
AAC supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
DTS supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
ATRAC supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
DSD supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
EAC3 supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
DTS_HD supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
MLP supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
DST supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
WMAPRO supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
Extended supported: Max channels: 8, Max samplerate: 192kHz, Max rate 2040 kb/s.
Thank you for your help
