I installed the alarm clock service and it works great, but finding it in the menus is a nightmare. Is there a simple way to access it from the remote app on the phone? Or is there an add-on I could use instead so that it’s easy to find from the list of add-ons in the remote app?
Depending on the skin you are using, I believe you can add it to the main menu.
I’m using the osmc skin. I tried to add it to the menu from the skin configuration but it doesn’t seem to be possible.
I can add “services” but this is not in there
