hi guys can emulation station be installed with osmc on the same sd card ?
It worked for me in Alpha 4 but a lot of packages are missing in RC at least for the Pi 2.
Seems like not every package has made it to the RPi 2 optimized repo yet.
I’ll try to make a chroot for raspbian and try to install it there.
@mcobit thanks for the reply m8 im running osmc rc version have u a guide so as I can install emulation station to the same sd card as well thanks
Working on it.
@mcobit ok thanks m8
Have a look here:
@mcobit noob question how do I stop kodi m8 via ssh ?
If you run the script it will stop it automatically. If you want to stop it manually, type
sudo service mediacenter stop
