Do we have any property set in OSMC to enable wifi tethering? I am trying “sudo connmanctl tether wifi on”, but it doesnt work.
What is the error message ?
If it doesn’t work, most likely the wifi driver for your wireless adaptor does not support Host AP mode.
It worked now. I was running the command in connmanctl, I had to exit and do it again.
My mistake
