since with vero, we have a solution to play the H265,
which the less expensive hardware solution is to encode?
(Which does not use the resources of a PC and except … build another MiniPC with a gtx 960 too expensive …)
Does it exist?
thank you
Does it exist?
thank you
The Vero 2 can encode H265 content in hardware, this would require an interface to amcodec which doesn’t exist at this time.
I would recommend not encoding in H265 for a while yet. By the time you encode your library (assuming it is large), the encoders will have improved further and you will likely need to re-encode again!
OK Thank You,
I’m waiting (Especially the dedicated mini PC + nvidia 960 is expensive solution)
An interface to encode with a Vero is planned ?
It isn’t planned as I don’t think there would be much demand for it.
You can use libx265 on PC, no idea how fast it will be to encode though. I am not sure if CUDA (nvidia) supports h265 encoding.
isn’t planed …
It’s a pity!
nvidia ?
Guide to HEVC/H.265 Encoding and Playback > How to Encode HEVC: Utilizing Nvidia GPU Hardware Acceleration | TechSpot
and youtube (for me in french), with 960-970 and 980 =>
https://www.youtube.com/watch?v=c2toCMJ2wZk
but it is expensive with a pc dedicated solely to this function … (gtx 960 = 200€ + a PC)
I’ll wait for a solution … the H265 will end up becoming a must
thank you
