Hello,
I have had Vero 4K+ for a while, and just recently I tried to configure tvheadend 4.2.8 on it. As the add-on seems to work fine, I cannot get the “EPG Grabber Modules” tab to show. I’ve read many posts regarding the issue, and found that “Persistent user interface level” in General->Base should be checked, as well the “User interface level” should be Expert mode.
Right after checking the box next to the “Persistent user interface level” and saving the change, all configuration tabs disappeared from the menu. Only “Electronic Program Guide”, “Digital Video Recordrer”, “About” are visible. I no longer see “Configuration” tab, Login link, storage space. I cleared cache in the browser, tried different computer. No changes.
Why did this happen? Is there a way to restore all tabs again?
I have tried tvheadend 4.2.8 on a different platform LibreELEC on RaspPi3b+ (hope I can say this here), and all tabs, including “EPG Grabber modules”, are visible, no issues at all.
