EPG guide fails to play (using TVHeadend). Skin error?
I have a weird problem.
Long story made short: Had a perfectly working system. Then YouSee changed channels on cableTV and I had to make a new search in TVHeadend. My TVHeadend is running on another machine and not installed on the Vero. But the TVHeadend server didn’t like that and decided to crash, so a total reinstall of my TVHeadend backend was necessary. Got TVHeadend up and running again, and it works perfectly. Tested with 4 other maskines.
Now the problem:
If I use the OSMC skin, then I can’t watch a channel chosen from the EPG guide menu. Absolutly nothing happends.
If I use the Channel menu then I can watch TV.
I can reproduce the problem on both a Vero1 and a Pi1
Did some testing:
I reinstalled Vero.
If I start on the Confluence skin, then watching channels selected from the EPG guide menu WORKS.
Switch to OSMC skin, and watching channels selected from the EPG guide menu FAILS.
Switch back to Confluence skin, and watching channels selected from the EPG guide menu also FAILS.
Is the OSMC skin broken? :slightly_smiling:
Booted to Confluence skin
Switched to OSMC skin
Switched back to Confluence skin
Logs at http://paste.osmc.io/eroreciciv
