Yes my VM does not have arp installed, apt-get install arp doesn’t work.
I unplugged the vero 4k and then plugged in the 4k+ in the same spot
through wireless I am able to download the update.
I have not rebooted my router yet, I had it plugged into my cisco gigabit switch but I was getting no wired connection, once I switched it to the mikrotik it resolved the issue
Okay connectivity issue has been resolved, there was an ARP entry for the old Vero 4k which I removed now I am ping everything from the previous tests successfully and it says in My OSMC Connected where it was saying No Internet. however I am still “Unable to connect to remote server.” when scanning for new content, and when I click on get more skins it does nothing. Here are the logs I just grabbed. https://paste.osmc.tv/nejomugibe
Seems to be some scraper issue
Maybe try to catch that webpage from your PC and also with wget/curl from the Vero to see whats going on.
12:42:08.376 T:3610366720 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 401
12:42:08.376 T:3610366720 ERROR: CCurlFile::Open failed with code 401 for https://api.thetvdb.com/search/series?name=The_Secret_Life_of_Machines
12:42:08.377 T:3610366720 ERROR: Run: Unable to parse web site
from every test I’ve run I have complete connectivity, I can ping both that you mentioned, I am getting 401 error in the logs when trying to scan for new content
also scanning for new content also looks like it’s working now too, I guess it’s not did you trying turning it off and on again anymore, it’s did you turning it off and on again twice yet?
