I know just enough about building executables in OSMC to be dangerous, but not enough to get myself out of my own messes … as evidenced by my problem.
I’m pretty sure that I’m encountering this because I installed armv7-toolchain-osmc to build my own copy of kodi.bin (see Comskip/EDL processing bug in KODI (?))
When trying to upgrade, I get the message on the screen “Error installing: armv7-toolchain-osmc (1.4.3)”
In the logs (https://paste.osmc.tv/ibaviquqew) I see this …
Preparing to unpack .../armv7-toolchain-osmc_1.4.3_all.deb ...
e[1mdpkg:e[0m error processing archive /var/cache/apt/archives/armv7-toolchain-osmc_1.4.3_all.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
I tried removing the package but got this …
osmc@osmc:~ $ sudo apt-get remove armv7-toolchain-osmc
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
[long list of packages]
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 250 MB disk space will be freed.
(Reading database ... 50949 files and directories currently installed.)
Removing armv7-toolchain-osmc (1.4.0) ...
dpkg: error processing package armv7-toolchain-osmc (--remove):
subprocess installed pre-removal script returned error exit status 1
osmc@osmc:~ $
Short of a fresh clean install of OSMC … any ideas?
