Sorry for my bad english
I try to install last update of my OSMC with the file rbp-bootloader-osmc_1.8.0-1_armhf.deb
I don’t understand the error… please you have an idea ?
See the log command prompt :
Reading package lists… Done
Building dependency tree
E: Unable to locate package rbp-bootloader-osmc_1.8.0-1_armhf.deb
E: Couldn’t find any package by regex ‘rbp-bootloader-osmc_1.8.0-1_armhf.deb’
root@osmc:/var/cache/apt/archives# sudo dpkg -i rbp-bootloader-osmc_1.8.0-1_armh f.deb
(Reading database … 36310 files and directories currently installed.)
Preparing to unpack rbp-bootloader-osmc_1.8.0-1_armhf.deb …
/boot is not mounted!
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead …
dpkg: error processing archive rbp-bootloader-osmc_1.8.0-1_armhf.deb (–install) :
subprocess new pre-removal script returned error exit status 1
Edit
This is a install to “Raspberry Pi Bootloader components”
