sam
23 February 2016 15:24
1
Hi, I can not install samba from the app store (or any other app), every time it give me an error. I’ve tried to reinstall the OSMC, but I get always the same error, I tried diferent SD cards too but always the same error.
So I ask you help and here is my log:
http://paste.osmc.io/dahoduyase
Many thanks in advance and keep up the god work.
mcobit
23 February 2016 15:30
2
Can you ssh in and see if
sudo apt-get update
works?
Please enable debugging and try again to go to APP Store and install something and sent then logs.
Also either try like mcobit wrote to update from command line or from MyOSMC.
sam
23 February 2016 15:55
4
Yes I can ssh and I’ve executed the sudo apt-get update, here is the result:
osmc@osmc:~$ sudo apt-get update
Hit http:// mirrordirector.raspbian.org jessie InRelease
Hit http:// apt.osmc.tv jessie InRelease
Hit http:// mirrordirector.raspbian.org jessie/main armhf Packages
Hit http:// mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http:// mirrordirector.raspbian.org jessie/non-free armhf Packages
Get:1 http:// apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Ign http:// apt.osmc.tv jessie/main Translation-en
Ign http:// mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http:// mirrordirector.raspbian.org jessie/main Translation-en
Ign http:// mirrordirector.raspbian.org jessie/non-free Translation-en
Fetched 2023 B in 26s (75 B/s)
Reading package lists… Done
osmc@osmc:~$
Now I have debug enabled and after the update via ssh I tried again the samba install with the same error, here is the new log: http://paste.osmc.io/hixudutila
Thanks.
Can you try from ssh
curl http://mirrordirector.raspbian.org/raspbian/pool/main/g/gdbm/libgdbm3_1.8.3-13.1_armhf.deb
sam
23 February 2016 16:02
6
Result:
osmc@osmc:~$ curl http://mirrordirector.raspbian.org/raspbian/pool/main/g/gdbm/libgdbm3_1.8.3-13.1_armhf.deb
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="http://raspbian.mirror.root.lu/raspbian/pool/main/g/gdbm/libgdbm3_1.8.3-13.1_armhf.deb">here</a>.</p>
<hr>
<address>Apache/2.2.22 (Debian) Server at mirrordirector.raspbian.org Port 80</address>
</body></html>
sam
24 February 2016 11:51
8
Is it possible to install samba via ssh?
sudo apt-get update
sudo apt-get install smb-app-osmc
You could do it like dbmandrake wrote but to be honest I would not trust a system that doesn’t work within Kodi
sam
24 February 2016 19:51
11
Thanks for you help, but even ssh dont work Iget the following
Err http:// Index of /raspbian jessie/main libgdbm3 armhf 1.8.3-13.1
404 Not Found
Err http:// Index of /raspbian jessie/main libhdb9-heimdal armhf 1.6~rc2+dfsg-9+rpi1
404 Not Found
Err http:// Index of /raspbian jessie/main python-dnspython all 1.12.0-1
404 Not Found
Err http:// Index of /raspbian jessie/main python-ntdb armhf 1.0-5
404 Not Found
Err http:// Index of /raspbian jessie/main python-tdb armhf 1.3.1-1
404 Not Found
Err http:// Index of /raspbian jessie/main python-crypto armhf 2.6.1-5
404 Not Found
Err http:// Index of /raspbian jessie/main tdb-tools armhf 1.3.1-1
404 Not Found
Err http:// Index of /raspbian jessie/main libfile-copy-recursive-perl all 0.38-1
404 Not Found
Err http:// Index of /raspbian jessie/main update-inetd all 4.43
404 Not Found
Err http:// Index of /raspbian jessie/main libkdc2-heimdal armhf 1.6~rc2+dfsg-9+rpi1
404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/g/gdbm/libgdbm3_1.8.3-13.1_armhf.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/h/heimdal/libhdb9-heimdal_1.6~rc2+dfsg-9+rpi1_armhf.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/d/dnspython/python-dnspython_1.12.0-1_all.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/n/ntdb/python-ntdb_1.0-5_armhf.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/t/tdb/python-tdb_1.3.1-1_armhf.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/p/python-crypto/python-crypto_2.6.1-5_armhf.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/t/tdb/tdb-tools_1.3.1-1_armhf.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/libf/libfile-copy-recursive-perl/libfile-copy-recursive-perl_0.38-1_all.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/u/update-inetd/update-inetd_4.43_all.deb 404 Not Found
E: Failed to fetch http:// mirrordirector.raspbian.org/raspbian/pool/main/h/heimdal/libkdc2-heimdal_1.6~rc2+dfsg-9+rpi1_armhf.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I dont know whats wrong with me or my Pi.
Ok, actually I looked in your Curl respone again. And actually the mirror seems to point to a broken mirror.
So as a temporary fix I suggest you change in /etc/apt/sources.list http://mirrordirector.raspbian.org/raspbian
with one of the mirrors from the list that is close to you (e.g. http://mirror.informatik.uni-mannheim.de/pub/linux/distributions/raspbian/raspbian/
http://www.raspbian.org/RaspbianMirrors
sam
25 February 2016 13:54
13
Many thanks to you guys for you help and time spended to help me.
It works now.
Again, thanks
Assuming that the problem with the mirror should be solved after a few days I suggest you try to change it back next.
