After transmission installation from app store I got an error and the message “report to forum”.
Here is the log: kodi.log - Pastebin.com
Thanks.
Thanks.
Can we have full set of logs and debugging enabled when you upload these logs?
on the way
Here is a detailed log, with debug enabled kodi.log - Pastebin.com
I’ve notice that transmission service appears as enabled, but I can not reach its web interface at my_IP:9091
Also, /home/OSMC/.config/transmission-daemos/settings.json are empty
Also I can’t start or stop with sudo service transmission start throuhg ssh:
osmc@osmc:~$ sudo service transmission startJob for transmission.service failed. See 'systemctl status transmission.service' and 'journalctl -xn' for details.
osmc@osmc:~$ systemctl status transmission.service
● transmission.service - Transmission BitTorrent Daemon
Loaded: loaded (/lib/systemd/system/transmission.service; enabled)
Active: failed (Result: exit-code) since sáb 2015-06-27 17:22:42 UTC; 8s ago
Process: 903 ExecStart=/usr/bin/transmission-daemon -f --log-error (code=exited, status=255)
Main PID: 903 (code=exited, status=255)
I’ll go to reinstall osmc from scratch. There are a lot of faliures. Past week I did a well working installation and the same steps didn’t work today.
Thank you anyway.
I’ve made some improvements to Transmission, things should be better now
Sorry about delay. After a new OSMC installation everything is ok.
