Hi, I am getting an error message while trying to install the latest update.
It exits Kodi and starts doing it thing, but after a while, I get:
An error occured while installing the following package: (unknown package).
Please report ...
It starts Kodi after 30 seconds and shows an error dialog in there as well saying OSMC Update Error, Error installing: (unknown package), but nothing more specific.
I tried several times with same result. I also tried running sudo apt-get update and sudo apt-get dist-upgrade, but it crashed a few seconds after saying yes to what packages will be installed/updated with the following:
Preconfiguring packages ...
dpkg: unrecoverable fatal error, aborting:
files list file for package `rbp2-image-4.4.16-1-osmc' contains empty filename
E: Sub-process /usr/bin/dpkg returned an error code (2)
Log started: 2016-09-01 11:58:13 files list file for package rbp2-image-4.4.16-1-osmc’ contains empty filename
Log ended: 2016-09-01 11:58:15`
Seems the package is damaged, suggest you try to clear the apt-cache and try to download again.
Okay, the issue is still not fixed, but I got further. The problem is with the rbp2-image-4.4.16-1-osmc package, which is not the newest one, as I see there is already the rbp2-image-4.4.16-4-osmc package, which apt wants to install as well. However, I do not know how to get rid of the rbp2-image-4.4.16-1-osmc package. I tried sudo apt-get clean, sudo apt-get autoclean, I also tried sudo apt-get autoremove and specifically sudo apt-get remove rbp2-image-4.4.16-1-osmc, but none of those helped.
Even though the corrupted package is no longer listed between the packages, which are to be installed (see below), I still get the same error as before.
$ sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
base-files-osmc gnupg gpgv libgcrypt20 mediacenter-addon-osmc
rbp-bootloader-osmc rbp-userland-osmc rbp2-kernel-osmc rbp2-mediacenter-osmc
9 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 59.0 MB of archives.
After this operation, 65.4 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://security.debian.org/ jessie/updates/main libgcrypt20 armhf 1.6.3-2+deb8u2 [355 kB]
<left out some gets here>
Fetched 59.0 MB in 1min 37s (603 kB/s)
Do you know how to (perhaps manually) get rid of the `rbp2-image-4.4.16-1-osmc’ package?
I did first 3 steps, but when I ran sudo apt-get dist-upgrade, it says:
You might want to run 'apt-get -f install' to correct these.
rbp2-kernel-osmc : Depends: rbp2-image-4.4.16-1-osmc but it is not installed
E: Unmet dependencies. Try using -f.
So, should I force it (like sudo apt-get -f dist-upgrade)?
Alright, that seems to have worked, dist-upgrade ran without errors. On the main screen however, I still see the updates available icon. When I go to My OSMC I see version OSMC August 2016 2016.08-1. Shouldn’t it end with a 08-4 ?
i have tried all the different commands for the upgrade even going through the GUI just says error.
After this operation, 0 B of additional disk space will be used.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = “en_US.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
