Tried diverting JustBoomDigi but didnt seem to work.
I know Ive not got the “cleanest” osmc with some customisations, but Ive always managed to get it to update… cant imagine having to do a clean rebuild- it would be most painful!
Unpacking rbp-userland-osmc (2.3.1-1) over (1.7.0-1) …
dpkg: error processing archive /var/cache/apt/archives/rbp-userland-osmc_2.3.1-1_armhf.deb (–unpack):
trying to overwrite ‘/usr/bin/raspi-config’, which is also in package raspi-config 20161207
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack …/rbp2-device-osmc_1.4.0_armhf.deb …
Unpacking rbp2-device-osmc (1.4.0) over (1.3.3) …
dpkg: error processing archive /var/cache/apt/archives/rbp2-device-osmc_1.4.0_armhf.deb (–unpack):
trying to overwrite ‘/usr/share/alsa/cards/JustBoomDigi.conf’, which is also in package libasound2-data 1.0.28-1+rpi2
trying to overwrite ‘/usr/bin/raspi-config’, which is also in package raspi-config 20170503
Processing triggers for libc-bin (2.19-18+deb8u9) …
osmc@osmc:~$ sudo apt-get --purge remove raspi-config
Reading package lists… Done
Building dependency tree
You might want to run ‘apt-get -f install’ to correct these:
rbp-userland-dev-osmc : Depends: rbp-userland-osmc (= 2.3.1-1) but 1.7.0-1 is to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
yea gave that a go… still no bananas.
EDIT: seems the offending package was raspi-config… removed the sucker, everything else seemed to come good
sudo dpkg -P raspi-config
only got this lot now, which doesnt look too serious…??
W: GPG error: http://mirrordirector.raspbian.org jessie InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Jun 21 19:50:38 2017 from achandra-lap
osmc@osmc:~$ sudo apt-get -f install
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
rbp2-image-4.4.27-7-osmc rbp2-image-4.4.27-9-osmc
Use ‘apt-get autoremove’ to remove them.
The following extra packages will be installed:
rbp-userland-osmc
rbp-userland-osmc
1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
6 not fully installed or removed.
Need to get 0 B/1195 kB of archives.
After this operation, 17.4 kB of additional disk space will be used.
Setting up debian-archive-keyring (2017.5~deb8u1) …
Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-squeeze-automatic.gpg …
Removing obsolete conffile /etc/apt/trusted.gpg.d/debian-archive-squeeze-stable.gpg …
(Reading database … 78766 files and directories currently installed.)
Preparing to unpack …/rbp-userland-osmc_2.3.1-1_armhf.deb …
Unpacking rbp-userland-osmc (2.3.1-1) over (2.2.0-1) …
trying to overwrite ‘/usr/bin/raspi-config’, which is also in package raspi-config 20160527
Processing triggers for libc-bin (2.19-18+deb8u10) …
osmc@osmc:~$
osmc@osmc:~$ sudo apt-get install --reinstall rbp-userland-osmc
rbp-userland-osmc
5 not fully installed or removed.
osmc@osmc:~$
i’ve also had problems on updating my system, but solved it like so: dpkg -l | grep "<package name>". If the package that causes the problem it’s still listed, uninstall it with dpkg like so: sudo dpkg -r <package name> and purge it’s config files using sudo dpkg -P <package name> . Hope this helps.
Just reporting back mines all sorted…
All nicely updated/upgraded to latest.
it did complain about that source again as follows:
W: GPG error: http://archive.raspberrypi.org jessie InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY
but a quick google to add the key back and now clean as a whistle!
Take note of the 16 digit key and place it into the following statement.
Yea, I would’ve added this source to add customisations/packages. One of the reasons I and I expect a number of other OSMC users chose OSMC, is due to its flexibility and possibility of running other stuff other than OSMC in tandem on my Pi3. So believe it would benefit others who like me would have additional stuff running on top of OSMC.
Im not running anything too silly; just RetrOSMC, measureIT solar/power monitoring and Squeezebox server.
Appreciate the help even though your within your rights of course to tell us custom users to bugger off!
