ERROR: Open - error probing input format
Hi Sam are you ok. No I pushed the stream through my CDN and it did the same thing. When I Installed RC2 it worked
I can clearly see from your log that this is update did not occur.
Hi ,
Thanks again . using the same method and using RC2 it does not happen , it works .
different sd card pal . I used this one to show you the error
I would not lie about updating it , if it worked I wouldn’t need to ask questions.I am updating this again through OSMC and will send you the log asap.
cheers
http://paste.osmc.io/eboyirakiw
Thanks again for your time
any ideas guys?
