hi. When i restart Raspberry pi 2 , it’s very long to start and then show message “Error Skin Shortcuts” . OSMC App doesn’t start and show the message “OSMC setting service failed to launch”
here is the log http://paste.osmc.io/oxoyubusog
i try to set OSMC skin but now OSMC doesn’t start
it soon a very long list on a screen where i can see “failed to start login service”
I have not other add-on. Only key map
thanks, but it’s very difficult for me to understood…
i will try to reinstall OSMC on SD card.
the problem i have Pifi digi+ card and the re-install is more long
