Hello guys,
i’ve tried to update my Flexget version with this command:
pip install --upgrade flexget
it begins to download and install some packets, when i receve this error:
File "/usr/local/bin/pip", line 11, in <module>
sys.exit(main())
File "/usr/local/lib/python2.7/dist-packages/pip/__init__.py", line 217, in main
return command.main(cmd_args)
File "/usr/local/lib/python2.7/dist-packages/pip/basecommand.py", line 248, in main
pip_version_check(session)
File "/usr/local/lib/python2.7/dist-packages/pip/utils/outdated.py", line 102, in pip_version_check
installed_version = get_installed_version("pip")
File "/usr/local/lib/python2.7/dist-packages/pip/utils/__init__.py", line 858, in get_installed_version
working_set = pkg_resources.WorkingSet()
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 629, in __init__
self.add_entry(entry)
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 685, in add_entry
for dist in find_distributions(entry, True):
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 2075, in find_eggs_in_zip
if metadata.has_metadata('PKG-INFO'):
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 1605, in has_metadata
return self.egg_info and self._has(self._fn(self.egg_info, name))
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 1963, in _has
return zip_path in self.zipinfo or zip_path in self._index()
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 1843, in zipinfo
return self._zip_manifests.load(self.loader.archive)
File "/usr/local/lib/python2.7/dist-packages/pip/_vendor/pkg_resources/__init__.py", line 1783, in load
mtime = os.stat(path).st_mtime
OSError: [Errno 2] No such file or directory: '/usr/local/lib/python2.7/dist-packages/feedparser-5.2.0-py2.7.egg'
Any ideas ?
Thank you!!
