Hi guys,
I am having no luck updating my Pi2B+ to the latest OSMC.
I am still on OSMC 2017.10-1 as every subsequent update failed since.
Logs from the latest manual update attempted at https://paste.osmc.tv/axubajefap
Could you let me know what is going wrong and how can i fix it please?
Thank you for your help
It looks like there might be a corrupt file that’s preventing the update to Debian stretch.
Try this:
sudo find /var/lib/apt/lists -type f -delete
sudo apt-get update
sudo apt-get dist-upgrade
If it works, you’ll soon know since it’ll need to download a few hundred megabytes to complete the upgrade.
Thank you. That helped.
After running the commands you suggested from my PC I went to my RPi and it seemed to be stuck on some updates.
“[OK] Started Updated UTMP about System Runlevel Changes.”
Waited for 20min but no progress.
After unplugin the Pi from power, on next reboot it did a successful update to Mar2018 OSMC version.
Thank you again!
