I’m new to OSMC. I just installed it on a 16 gb class 10 micro sd with the installer, without encountering errors; but on the restart it appeared written this: (sending the link of pastebin) grep: error while loading shared libraries: /lib/arm-linux-gnueabihf/libdl.so.2: - Pastebin.com. I turned off and turned on the Raspberry Pi 3B, but the same thing happens. Sorry for the bad english!
I would recommend trying a different SD card.
Thank you, now I try with another micro sd
It worked!
You may want to use a tool like h2testw to check that other SD card to see if it is defective or a fake.
