Checking the log there are some unmatched parentheses in the skin.osmc xml.
There is also a reference to an absent Coordinates_Includes_DialogSettings.xml
Skin has invalid include: FullScreenOverlayDimensions string.isempty(window(12005).property(videoosdfresh) string.isempty(window(12006).property(musicosdfresh)
string.isequal(101001).listitem.title,no information available)
string.isequal(101101).listitem.title,no information available)
more general errors with script.module items:
script.module.dateutil is not compatible with Kodi (19)
script.module.arrow has an unsatisfied dependency: xmbc.python v 2.25.0 failed to download;
script.module.dateutil-2.8.1 matrix.1.zip; curl open failed code 0 (possibly typo? space instead of dash or underscore?)
script.module.backports.functools_lru_cache is not compatible with Kodi
script.module.soupsieve is not compatible with Kodi
script.module.beautifulsoup4 is not compatible with Kodi
script.module.pycaption has an unsatisfied dependency on xbmc.python v 2.26.0
and lastly a general error: Exception: Non-Existent Control 300
reproduce the issue
