Errors with module building
For the time I own it I build a networking module for a wifi adapter which used to work. Recently and I think when the kernel was upgraded to 4.14 It fails to build with this error:
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.14.26-4-osmc/build M=/home/osmc/r tl8723bu modules
make[1]: Entering directory ‘/usr/src/rbp1-headers-4.14.26-4-osmc’
CC [M] /home/osmc/rtl8723bu/core/rtw_cmd.o
In file included from ./include/linux/netfilter.h:8:0,
from ./include/linux/netfilter/nf_conntrack_tuple_common.h:6,
from ./include/linux/netfilter/nf_conntrack_dccp.h:29,
from ./include/net/netns/conntrack.h:11,
from ./include/net/net_namespace.h:27,
from ./include/linux/netdevice.h:42,
from /home/osmc/rtl8723bu/include/osdep_service_linux.h:34,
from /home/osmc/rtl8723bu/include/osdep_service.h:40,
from /home/osmc/rtl8723bu/include/drv_types.h:32,
from /home/osmc/rtl8723bu/core/rtw_cmd.c:22:
./include/linux/if.h:28:54: fatal error: sys/socket.h: No such file or directory
#include <sys/socket.h> /* for struct sockaddr. */
compilation terminated.
scripts/Makefile.build:320: recipe for target ‘/home/osmc/rtl8723bu/core/rtw_cmd .o’ failed
make[2]: *** [/home/osmc/rtl8723bu/core/rtw_cmd.o] Error 1
Makefile:1508: recipe for target ‘module/home/osmc/rtl8723bu’ failed
make[1]: *** [module/home/osmc/rtl8723bu] Error 2
make[1]: Leaving directory ‘/usr/src/rbp1-headers-4.14.26-4-osmc’
Makefile:322: recipe for target ‘modules’ failed
make: *** [modules] Error 2
I download the headers for the kernel version and use this ln:
sudo ln -s /usr/src/rbp1-headers-4.14.26-4-osmc /lib/modules/$(uname -r)/build
Any ideas?
Thanks!
If you tell us exactly what you did, then maybe someone can either see what went wrong or try it themselves. Right now, neither of these can happen.
#include &lt;sys/socket.h&gt;   /* for struct sockaddr.  */
I assume you have already installed the build-essential package. File sys/socket.h is part of the libc6-dev package, which should have been installed as a dependency of build-essential.
I am currently encountering the same error while trying to compile a driver for my wifi dongle. were you able to solve this issue? please tell how.
This appears to be an issue with the build of the OSMC kernel headers.
See Has anybody tried to install Wireguard? - #26 by dillthedog for further details.
I know @sam_nazarko has been very busy with Kodi 18, so it might still be on the list of things to do.
It is.
Any updates on this? I’m still running into this issue on the 2019.11-1 build.
