It’s a brand new install of 2015.06-1 on an RPi2 with both MPEG2 and VC-1 codec licenses installed. I go to Video Addons and select the ESPN3 addon and choose install. Everything seems to go ok (2 or 3 other Addons are installed as well… i guess dependencies). However, when i open the Addon and choose anything (Live, Last 10 days, etc…), i get an error message about an error with a script.
not sure i follow since ESPN3 doesn’t require a valid provider account or espn.go account, that is, anyone can go to espn.go.com and choose a stream from espn3 and start watching… just did it.
@Toast, yeah, i couldn’t glean anything useful from that thread. Being a new Kodi/OSMC user, i’m just now beginning to figure out what entity is responsible for what code/app/addon. I agree, i need to be reading through and posting to the kodi forums for this issue.
Everything you name are container formats and not codecs.
Decoding videos (regardless if they are stored locally or streamed) would require the licence keys if they are encoded in MPEG2 or VC1
Not sure what you mean with gdrive plugin.
But as long as the codec is one of the two mentioned of either the video file or stream it would be required.
Ok so that plugin will just “transfer” the video from gdrive to OSMC which then would decode it.
So as mentioned depending on the codec used on your video files you might require the licence
CODEC = enCOder/DECoder note the capitals. Codecs are what are used to turn the bits in the file to watchable video and audio. Gdrive videos will use whatever they use depending on how the file was written as all videos will. mpeg2 is a common codec that is used in a lot of videos see here So: what can I do with those video codecs? - Raspberry Pi
Save yourself some headaches and just get the codecs from here MPEG-2 license key - Raspberry Pi Store
The formats covered by the sold codecs are copyrighted and that is why you have to pay to use them. The RaspberryPi Foundation decided to sell them separately instead of putting them in the purchase price to keep the Pi as low cost as possible
