Actually I’m running Kodi 20.1 with OSMC default skin. When I try to change to Estuary skin I’m getting error / message that there were problems with it. Previously I performed “Reset Kodi on next reboot”
Are you referring to the ‘can’t build menu’ error message? If so that is a known issue without a known solution. It doesn’t actually affect anything so it can safely be ignored. It only shows up if you have the “skin shortcuts” add-on installed and enabled. You can disable it but this limits skin customization for skins that use it.
It seems you have a issue with Overscan. Ensure that you did not have any calibration configuration in Kodi/OSMC and use one of the following methods depending on the TV Brand you use.
Samsung TV - go to Menu / Picture / Picture Options / Size / Screen Fit (instead of 16:9).
LG TV - go to Settings / Picture / Aspect Ratio / Just Scan (instead of 16:9)
Sony TV - hit Home button, go to Settings / Screen / Display Area / Full Pixel
Sharp TV - hit View Mode button, select “Dot by Dot” or “Full screen”
Sharp Aquos - go to Menu / System Options / View Option / View Mode / Dot by Dot
Panasonic TV - go to Menu / Picture / Screen Settings / 16:9 Overscan / Off
Either you or some weird script has done something very strange to the Estuary folder. Estuary doesn’t use Skin Shortcuts (or any other addon), but I see in the log that you have a file from Skin Shortcuts in:
