Hi Sam/all,
Was going to reply to the main thread but it’s closed.
My unit was performing fine until a few days ago. I’d just been watching series on continuous play, no issues.
Finally went to browse through my films and check everything was listed (been having issues with the naming of Alien 3), noticed this was a bit jerky. Went back to playing content and it was suddenly freezing, buffering, saying it was too slow for continuous playback.
So this test was done with a PC (Intel I218V) wired to a BT Home Hub 6 (also checked with a Plusnet Hub One) then wired into the Vero4k+. Results are fine one way but not the other.
osmc@vero4kliving:~$ iperf3 -R -c 192.168.1.65
Connecting to host 192.168.1.65, port 5201
Reverse mode, remote host 192.168.1.65 is sending
[ 4] local 192.168.1.64 port 45004 connected to 192.168.1.65 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 109 MBytes 914 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 938 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 937 Mbits/sec
[ 4] 3.00-4.00 sec 111 MBytes 935 Mbits/sec
[ 4] 4.00-5.00 sec 112 MBytes 938 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 938 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 937 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 937 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 939 Mbits/sec
[ 4] 9.00-10.00 sec 80.9 MBytes 678 Mbits/sec
[ 4] 0.00-10.00 sec 1.06 GBytes 909 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.06 GBytes 909 Mbits/sec receiver
iperf Done.
osmc@vero4kliving:~$ iperf3 -c 192.168.1.65
[ 4] local 192.168.1.64 port 45006 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 1.53 MBytes 12.8 Mbits/sec 51 2.85 KBytes
[ 4] 1.00-2.00 sec 1.99 MBytes 16.7 Mbits/sec 98 4.28 KBytes
[ 4] 2.00-3.00 sec 1.17 MBytes 9.80 Mbits/sec 39 5.70 KBytes
[ 4] 3.00-4.00 sec 2.66 MBytes 22.3 Mbits/sec 101 2.85 KBytes
[ 4] 4.00-5.00 sec 754 KBytes 6.18 Mbits/sec 29 5.70 KBytes
[ 4] 5.00-6.00 sec 1.68 MBytes 14.1 Mbits/sec 64 2.85 KBytes
[ 4] 6.00-7.00 sec 971 KBytes 7.95 Mbits/sec 36 4.28 KBytes
[ 4] 7.00-8.00 sec 3.18 MBytes 26.7 Mbits/sec 128 4.28 KBytes
[ 4] 8.00-9.00 sec 3.76 MBytes 31.6 Mbits/sec 149 2.85 KBytes
[ 4] 9.00-10.00 sec 1.79 MBytes 15.0 Mbits/sec 61 1.43 KBytes
[ 4] 0.00-10.00 sec 19.4 MBytes 16.3 Mbits/sec 756 sender
[ 4] 0.00-10.00 sec 19.4 MBytes 16.2 Mbits/sec receiver
iperf Done.
Is this the same issue? Strange that it’s only just reared it’s head.
If there were no updates done, I’d suggest a reboot of both the Vero and the NAS (file server, PC, whatever) and see if the problem clears up.
Vero has been rebooted as has the PC. Will try again later this evening.
OK better after a reboot, but still only half the expected speed going from the Vero, but seems to be fine without slowdowns now
[ 4] local 192.168.1.64 port 56499 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 111 MBytes 935 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 939 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 939 Mbits/sec
[ 4] 4.00-5.00 sec 109 MBytes 918 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 940 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 940 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 940 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 939 Mbits/sec
[ 4] 0.00-10.00 sec 1.11 GBytes 955 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.11 GBytes 955 Mbits/sec receiver
iperf Done.
[ 4] local 192.168.1.64 port 56501 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 47.6 MBytes 399 Mbits/sec 47 15.7 KBytes
[ 4] 1.00-2.00 sec 45.9 MBytes 385 Mbits/sec 45 20.0 KBytes
[ 4] 2.00-3.00 sec 47.9 MBytes 402 Mbits/sec 46 18.5 KBytes
[ 4] 3.00-4.00 sec 47.5 MBytes 398 Mbits/sec 47 22.8 KBytes
[ 4] 4.00-5.00 sec 50.5 MBytes 422 Mbits/sec 44 35.6 KBytes
[ 4] 5.00-6.00 sec 43.5 MBytes 367 Mbits/sec 55 20.0 KBytes
[ 4] 6.00-7.00 sec 37.9 MBytes 318 Mbits/sec 53 8.55 KBytes
[ 4] 7.00-8.00 sec 40.4 MBytes 339 Mbits/sec 44 15.7 KBytes
[ 4] 8.00-9.00 sec 41.0 MBytes 344 Mbits/sec 46 12.8 KBytes
[ 4] 9.00-10.00 sec 50.1 MBytes 420 Mbits/sec 53 20.0 KBytes
[ 4] 0.00-10.00 sec 452 MBytes 379 Mbits/sec 480 sender
[ 4] 0.00-10.00 sec 451 MBytes 379 Mbits/sec receiver
iperf Done.
480 retries still isn’t good.
Spoke too soon, 20 minutes into watching and bang, buffering…iperf3 results…
[ 4] local 192.168.1.64 port 56504 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 182 KBytes 1.49 Mbits/sec
[ 4] 1.00-2.00 sec 534 KBytes 4.37 Mbits/sec
[ 4] 2.00-3.00 sec 469 KBytes 3.84 Mbits/sec
[ 4] 3.00-4.00 sec 559 KBytes 4.58 Mbits/sec
[ 4] 4.00-5.00 sec 12.8 KBytes 105 Kbits/sec
[ 4] 5.00-6.00 sec 210 KBytes 1.72 Mbits/sec
[ 4] 6.00-7.00 sec 2.98 MBytes 25.0 Mbits/sec
[ 4] 7.00-8.00 sec 1.67 MBytes 14.0 Mbits/sec
[ 4] 8.00-9.00 sec 1.09 MBytes 9.12 Mbits/sec
[ 4] 9.00-10.00 sec 185 KBytes 1.52 Mbits/sec
[ 4] 0.00-10.00 sec 8.00 MBytes 6.71 Mbits/sec sender
[ 4] 0.00-10.00 sec 7.84 MBytes 6.57 Mbits/sec receiver
iperf Done.
[ 4] local 192.168.1.64 port 56506 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 2.01 MBytes 16.8 Mbits/sec 47 2.85 KBytes
[ 4] 1.00-2.00 sec 934 KBytes 7.65 Mbits/sec 35 4.28 KBytes
[ 4] 2.00-3.00 sec 576 KBytes 4.72 Mbits/sec 25 2.85 KBytes
[ 4] 3.00-4.00 sec 797 KBytes 6.53 Mbits/sec 41 2.85 KBytes
[ 4] 4.00-5.00 sec 1.77 MBytes 14.9 Mbits/sec 87 2.85 KBytes
[ 4] 5.00-6.00 sec 1.03 MBytes 8.61 Mbits/sec 50 4.28 KBytes
[ 4] 6.00-7.00 sec 1.64 MBytes 13.7 Mbits/sec 47 2.85 KBytes
[ 4] 7.00-8.00 sec 535 KBytes 4.38 Mbits/sec 29 2.85 KBytes
[ 4] 8.00-9.00 sec 952 KBytes 7.80 Mbits/sec 63 2.85 KBytes
[ 4] 9.00-10.00 sec 898 KBytes 7.36 Mbits/sec 50 4.28 KBytes
[ 4] 0.00-10.00 sec 11.0 MBytes 9.25 Mbits/sec 474 sender
[ 4] 0.00-10.00 sec 10.9 MBytes 9.13 Mbits/sec receiver
iperf Done.
Sorry to hear this.
The device won’t go bad after time. The issue would have been there to begin with.
Did you run an iperf3 test when you received the device?
Hi Sam, no, I thought about it when I saw the posts on here but had no issues with playback so forgot about it.
Do you have another switch or cable you can test with?
I assume 192.168.1.65 is the PC which is wired.
Yep it is. I can connect them direct, although I’ll need to find a keyboard to login to the Vero with. Out at the moment so I’ll give it a try tomorrow
Will try this tonight, wasn’t in yesterday.
@sam_nazarko apologies for the delay, here’s a direct connection between the Vero and my PC, same result. I guess I’ve got a broken one
[ 4] local 192.168.1.64 port 50470 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 1.36 MBytes 11.4 Mbits/sec
[ 4] 1.00-2.00 sec 12.8 KBytes 105 Kbits/sec
[ 4] 2.00-3.00 sec 0.00 Bytes 0.00 bits/sec
[ 4] 3.00-4.00 sec 620 KBytes 5.09 Mbits/sec
[ 4] 4.00-5.00 sec 37.4 MBytes 314 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 936 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 938 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 940 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 940 Mbits/sec
[ 4] 0.00-10.00 sec 599 MBytes 503 Mbits/sec sender
[ 4] 0.00-10.00 sec 599 MBytes 503 Mbits/sec receiver
iperf Done.
[ 4] local 192.168.1.64 port 50472 connected to 192.168.1.65 port 5201
[ 4] 0.00-1.00 sec 488 KBytes 3.99 Mbits/sec 41 2.85 KBytes
[ 4] 1.00-2.00 sec 275 KBytes 2.25 Mbits/sec 20 2.85 KBytes
[ 4] 2.00-3.00 sec 853 KBytes 6.98 Mbits/sec 79 1.43 KBytes
[ 4] 3.00-4.00 sec 637 KBytes 5.23 Mbits/sec 50 4.28 KBytes
[ 4] 4.00-5.00 sec 25.7 KBytes 210 Kbits/sec 9 1.43 KBytes
[ 4] 5.00-6.00 sec 106 KBytes 865 Kbits/sec 8 4.28 KBytes
[ 4] 6.00-7.00 sec 91.2 KBytes 747 Kbits/sec 23 2.85 KBytes
[ 4] 7.00-8.01 sec 304 KBytes 2.47 Mbits/sec 38 4.28 KBytes
[ 4] 8.01-9.00 sec 85.5 KBytes 706 Kbits/sec 12 2.85 KBytes
[ 4] 9.00-10.00 sec 515 KBytes 4.22 Mbits/sec 41 2.85 KBytes
[ 4] 0.00-10.00 sec 3.30 MBytes 2.77 Mbits/sec 321 sender
[ 4] 0.00-10.00 sec 3.23 MBytes 2.71 Mbits/sec receiver
iperf Done.
Sounds like it. Contact support@osmc.tv and we’ll get this sorted for you.
