Ethernet to WiFi Tethering to Increase Existing WiFi Range
Is it possible to connect the RPi3 via ethernet and create a WiFi hotspot to bolster an existing wireless network? Would be nice to have options when tethering to disable DHCP and set static IP addresses.
PS. - OSMC is fan-flippin-tastic!
Use the forum search feature, and I think that you will find the answer to your question :smiley_cat:
