raspberry PI 3
SD card 32 GB
Image succesfully installed on sd card
Raspberry PI message osmc succesfully installed
and then after a few minutes
black screen with a few lines
last line: switch_root: can’t execute ‘/sbin/splash_early’: Exec format error.
Already done the installation all over from formatting sd card to installation with de official osmc installer.
I’d try a new SD card.
Thanks Tom.
Its a card that I have already used with another OS for Raspberry and that worked.
I think there is nothing wrong with the card.
SD cards can fail.
On the same pi?
Thanks Tom.
Sure, on the same PI.
I would test the SD card with H2testw.
Thanks Tom.
I found it. I had tot format the card in overwrtie format and now it is OK.
Now struggling to reach the photo’s on my Synology Nas. Music seems OK but no sound when attaching a headphone.
Are you getting any error messages?
The analogue port on pi is not really suitable for headphones, as its not an active audio source. You’ve either need to attach the analogue or hdmi to a receiver and attach your headphones there or you could consider an USB DAC.
Thanks Tom.
No. When powered off/on it seemed to be disappeared. First I saw the maps, now nothing.
How are you trying to access the photos from your nas?
cifs, nfs?
Thanks Tom.
This would indicate the original problem of a broken SD card
