Hello,
I’m trying to mount a powered external USB drive to a Raspberry Pi 2. I already did set max_usb_current=1.
Here is the output from fdisk -l:
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 2048 499711 497664 243M c W95 FAT32 (LBA)
/dev/mmcblk0p2 501760 31115263 30613504 14.6G 83 Linux
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x7bc34569
/dev/sda1 2 1953525167 1953525166 931.5G 7 HPFS/NTFS/exFAT
I tried editing fstab, to no avail.
blkid produces the following output:
osmc@HanSolo:~$ blkid
/dev/mmcblk0p1: UUID=“CFA4-7A16” TYPE=“vfat” PARTUUID=“935cf2ac-01”
/dev/mmcblk0p2: UUID=“85f204c0-0d30-485f-adee-e6b37ca9bbc7” TYPE=“ext4” PARTUUID=“935cf2ac-02”
_/dev/mmcblk0: PTUUID=“935cf2ac” PTTYPE=“dos”
The output from lsusb is as follows:
osmc@HanSolo:~$ lsusb
Bus 001 Device 004: ID 174c:55aa ASMedia Technology Inc. ASMedia 2105 SATA bridge
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
I think the drive should be the ASMedia Technology Inc. thingy, but cannot understand why it’s not mounted or even recognized.
The system is up to date, the grab-logs output can be found here:
https://paste.osmc.tv/ewocemebod
I tried various helps and logs around, but cannot find a working solution. Can someone point me towards a solution?
