Hi all,
I cannot for the life of me figure out how to properly create a service to run ExpressVPN after boot on my rpi3. I’m able to SSH in & run it manually with the “expressvpn connect” command. I’ve attempted to change the rc.local and also to create a custom service and executable. Am I overcomplicating this?
I did at one point try this and kept receiving an AUTH failure.
Ok sounds like it needs a couple of extra steps:
<something>.conf - replace auth-user-pass with:
auth-user-pass /etc/openvpn/password
vi /etc/openvpn/password:
USERNAME
PASSWORD
Replace the above with username & password from ExpressVPN.
sudo systemctl start openvpn@something
If not please provide the output of:
systemctl status openvpn@something
Thanks Tom.
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: WARNING: this configuration may cache passwords in memory – use t
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: VERIFY OK: depth=1, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: VERIFY OK: nsCertType=SERVER
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: VERIFY X509NAME OK: C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: VERIFY OK: depth=0, C=VG, ST=BVI, O=ExpressVPN, OU=ExpressVPN, CN=
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-
Dec 27 16:40:41 osmc ovpn-newjersey[1692]: [Server-3550-0a] Peer Connection Initiated with [AF_INET]173.214.1
Dec 27 16:40:42 osmc ovpn-newjersey[1692]: SENT CONTROL [Server-3550-0a]: ‘PUSH_REQUEST’ (status=1)
Dec 27 16:40:42 osmc ovpn-newjersey[1692]: AUTH: Received control message: AUTH_FAILED
Dec 27 16:40:42 osmc ovpn-newjersey[1692]: SIGTERM[soft,auth-failure] received, process exiting
I missed two characters in the credentials. Everything is up and running. Thanks, you’re a life saver.
