ExpressVPN & OSMC?
Hi Team,
I have just installed OSMC/Kodi onto a Raspberry Pi 3+
I subscribe to ExpressVPN which I also would like to install on the Raspberry Pi.
When I go to the ExpressVPN site, there are a couple of options to choose.
Can you please assist in what I would need to download for a Pi that runs OSMC.
The options are:
  1. Ubntu
  2. Fedora
  3. Arch
  4. Raspbian
I am assuming the last but unsure if the Raspbian is compatible with OSMC.
Pete
ExpressVPN is, as most other VPN providers, using Openvpn. So the easiest is to use the Kodi Addon from Brian Hornsby.
Hey fzinken,
Thanks for that - yea, I’ll go and check it out.
Thanks again.
