I’ve read that the Vero 4k has an internal IR blaster, but not (yet?) the driver support for sending IR codes. Luckily I have an external Microsoft IR blaster (with a Philips chipset), which I used succesfully on my RP2 with OpenElec. However, I’m having issues getting it to work on the Vero 4k.
On booting the led (the normal one, not the ir led) flashes a few times as it also did on the RP2. After booting the led stays on. On the RP2 it stayed off and only flased when blasting. The device is recognized properly and appears in /dev/lirc1 and /var/run/lirc/lircd-lirc1. However, when I try to blast, nothing happens. No error and the IR led doesn’t light up.
irsend -d /var/run/lirc/lircd-lirc1 SEND_ONCE myremote KEY_VOLUMEDOWN
I also tried disabling the onboard blaster by blacklisting the ‘meson-ir’ driver in modprobe, but this didn’t make any difference.
Any idea on how to solve this?
There’s been a bit of discussion about the IR blaster.
It’s there, but we do not yet have a userspace interface for this for irsend to consume.
It’s something I would like to add in the future, but a couple of questions to guide things:
- Do you need to use ir-send, or would being able to use /dev/irblaster be OK?
- Do you know the carrier frequency and codes of the signals you’d want to send?
Does an external blaster need the same userspace interface or does it already have one?
I finally would like to use LIRC.Send() from Kodi, but any other solution I can call from Kodi is fine. However, I’m unaware of /dev/irblaster
I’m blasting to a Yamaha receiver. This is my lircd.conf:
begin remote
name myremote
bits 16
flags SPACE_ENC|CONST_LENGTH|REVERSE
eps 30
aeps 100
header 8853 4532
one 533 1714
zero 533 589
ptrail 533
pre_data_bits 16
pre_data 0x857A
gap 107903
toggle_bit 0
begin codes
KEY_VOLUMEUP 0x000000000000E51A
KEY_VOLUMEDOWN 0x000000000000E41B
end codes
end remote
Okay, that refines my expectations of what users would like.
I’ll ticket this and log your post so this isn’t forgotten, but it may be a bit of time until I can revisit.
Thanks, I’m looking forward to it
Robin
