Was working great for a year after this morning update it is not even recognized in my osmc–network and not working as well. Kindly tell me how do i roll back to previous update then today. I am linking my wifi dongle link here
Tried it still not detected neither working after reboot
Kindly give me link to download a previous update .deb file so that i can downgrade to build which was not affected by this iaaue.
There is most likely an easier way. Provide URL of dmesg | paste-log to confirm.
If your issue is that the device isn’t detected at all, then no kernel (previous or new) will resolve this.
Some logs may give clues. I’d be interested in seeing the dmesg output with the new kernel.
I typed dmesg | paste-log in terminal and got this
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 4.9.29-4-osmc (root@osmc) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Jun 6 11:19:47 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80e6f080, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 15 pages/cpu @aefa5000 s30592 r8192 d22656 u61440
[ 0.000000] pcpu-alloc: s30592 r8192 d22656 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 739352K/770048K available (8192K kernel code, 487K rwdata, 1984K rodata, 2048K init, 785K bss, 22504K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80900000 (9184 kB)
.init : 0x80c00000 - 0x80e00000 (2048 kB)
.data : 0x80e00000 - 0x80e79de8 ( 488 kB)
.bss : 0x80e7b000 - 0x80f3f564 ( 786 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000012] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000029] Switching to timer-based delay loop, resolution 52ns
[ 0.000353] Console: colour dummy device 80x30
[ 0.000379] console [tty0] enabled
[ 0.000408] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000431] pid_max: default: 32768 minimum: 301
[ 0.000805] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000819] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002095] Disabling cpuset control group subsystem
[ 0.002298] CPU: Testing write buffer coherency: ok
[ 0.002363] ftrace: allocating 20363 entries in 60 pages
[ 0.051387] CPU0: update cpu_capacity 1024
[ 0.051414] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.051487] Setting up static identity map for 0x100000 - 0x100034
[ 0.221522] CPU1: update cpu_capacity 1024
[ 0.221534] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.291569] CPU2: update cpu_capacity 1024
[ 0.291578] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.361681] CPU3: update cpu_capacity 1024
[ 0.361690] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.361805] Brought up 4 CPUs
[ 0.361820] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.361826] CPU: All CPU(s) started in HYP mode.
[ 0.361831] CPU: Virtualization extensions available.
[ 0.362925] devtmpfs: initialized
[ 0.375415] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.375814] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.375841] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.376633] pinctrl core: initialized pinctrl subsystem
[ 0.377921] NET: Registered protocol family 16
[ 0.380192] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.411576] cpuidle: using governor ladder
[ 0.441605] cpuidle: using governor menu
[ 0.441768] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.441778] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.441958] Serial: AMBA PL011 UART driver
[ 0.444328] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.533334] bcm2835-dma 3f007000.dma: DMA legacy API manager at af80f000, dmachans=0x1
[ 0.535615] SCSI subsystem initialized
[ 0.535817] usbcore: registered new interface driver usbfs
[ 0.535914] usbcore: registered new interface driver hub
[ 0.536064] usbcore: registered new device driver usb
[ 0.541912] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-04-04 18:50
[ 0.543313] clocksource: Switched to clocksource arch_sys_counter
[ 0.597397] VFS: Disk quotas dquot_6.6.0
[ 0.597505] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.597784] FS-Cache: Loaded
[ 0.598147] CacheFiles: Loaded
[ 0.614216] NET: Registered protocol family 2
[ 0.615445] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.615576] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.615765] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.615884] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.615943] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.616259] NET: Registered protocol family 1
[ 0.616910] RPC: Registered named UNIX socket transport module.
[ 0.616920] RPC: Registered udp transport module.
[ 0.616927] RPC: Registered tcp transport module.
[ 0.616933] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.729588] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.731154] audit: initializing netlink subsys (disabled)
[ 0.731230] audit: type=2000 audit(0.709:1): initialized
[ 0.732748] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.751673] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.753006] NFS: Registering the id_resolver key type
[ 0.753058] Key type id_resolver registered
[ 0.753065] Key type id_legacy registered
[ 0.759693] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.759871] io scheduler noop registered
[ 0.760496] io scheduler bfq registered (default)
[ 0.760503] BFQ I/O-scheduler: v8r7
[ 0.766220] BCM2708FB: allocated DMA memory ee500000
[ 0.766260] BCM2708FB: allocated DMA channel 0 @ af80f000
[ 0.828221] Console: switching to colour frame buffer device 240x67
[ 0.868955] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.869079] vc-cma: Videocore CMA driver
[ 0.869088] vc-cma: vc_cma_base = 0x00000000
[ 0.869096] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.869103] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.869376] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.890707] brd: module loaded
[ 0.902457] loop: module loaded
[ 0.902474] Loading iSCSI transport class v2.0-870.
[ 0.903428] usbcore: registered new interface driver smsc95xx
[ 0.903456] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.129673] Core Release: 2.80a
[ 1.129688] Setting default values for core params
[ 1.129710] Finished setting default values for core params
[ 1.330160] Using Buffer DMA mode
[ 1.330170] Periodic Transfer Interrupt Enhancement - disabled
[ 1.330175] Multiprocessor Interrupt Enhancement - disabled
[ 1.330186] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.330200] Dedicated Tx FIFOs mode
[ 1.330705] WARN::dwc_otg_hcd_init:1034: FIQ DMA bounce buffers: virt = 0xae514000 dma = 0xee514000 len=9024
[ 1.330744] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.330753] dwc_otg: Microframe scheduler enabled
[ 1.330821] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x806d589c
[ 1.330835] WARN::hcd_init_fiq:460: FIQ ASM at 0x806d5c0c length 36
[ 1.330850] WARN::hcd_init_fiq:486: MPHI regs_base at 0xaf87a000
[ 1.330931] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.330982] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.331028] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.331078] Init: Port Power? op_state=1
[ 1.331085] Init: Power Port (0)
[ 1.331445] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.331459] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.331470] usb usb1: Product: DWC OTG Controller
[ 1.331481] usb usb1: Manufacturer: Linux 4.9.29-4-osmc dwc_otg_hcd
[ 1.331491] usb usb1: SerialNumber: 3f980000.usb
[ 1.332601] hub 1-0:1.0: USB hub found
[ 1.332669] hub 1-0:1.0: 1 port detected
[ 1.333577] dwc_otg: FIQ enabled
[ 1.333585] dwc_otg: NAK holdoff enabled
[ 1.333592] dwc_otg: FIQ split-transaction FSM enabled
[ 1.333609] Module dwc_common_port init
[ 1.334025] usbcore: registered new interface driver usb-storage
[ 1.334407] mousedev: PS/2 mouse device common for all mice
[ 1.334867] usbcore: registered new interface driver usbtouchscreen
[ 1.335592] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.335949] bcm2835-cpufreq: min=600000 max=1000000
[ 1.338495] sdhci: Secure Digital Host Controller Interface driver
[ 1.338499] sdhci: Copyright© Pierre Ossman
[ 1.338736] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 1.338897] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.339477] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.339588] hidraw: raw HID events driver © Jiri Kosina
[ 1.339722] usbcore: registered new interface driver usbhid
[ 1.339726] usbhid: USB HID core driver
[ 1.340337] vchiq: vchiq_init_state: slot_zero = 0xae580000, is_master = 0
[ 1.341747] Initializing XFRM netlink socket
[ 1.341781] NET: Registered protocol family 17
[ 1.341887] Key type dns_resolver registered
[ 1.341977] Registering SWP/SWPB emulation handler
[ 1.342625] registered taskstats version 1
[ 1.344089] Key type encrypted registered
[ 1.344349] vc-sm: Videocore shared memory driver
[ 1.344359] [vc_sm_connected_init]: start
[ 1.348346] [vc_sm_connected_init]: end - returning 0
[ 1.352213] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.353669] sdhost: log_buf @ ae513000 (ee513000)
[ 1.433325] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.433501] of_cfs_init
[ 1.433592] of_cfs_init: OK
[ 1.455787] Freeing unused kernel memory: 2048K (80c00000 - 80e00000)
[ 1.500226] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.502056] mmc0: new high speed SDHC card at address 0001
[ 1.512797] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 1.514574] mmcblk0: p1 p2
[ 1.543606] Indeed it is in host mode hprt0 = 00021501
[ 1.631780] random: fast init done
[ 1.719004] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.728613] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 1.728817] fsck: Filesystem UUID: 23c7a0eb-9c37-452e-9e4c-b7487f55febc
[ 1.729039] fsck: /dev/mmcblk0p2: clean, 43497/1941504 files, 569256/7752448 blocks
[ 1.753371] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.753534] Indeed it is in host mode hprt0 = 00001101
[ 1.983628] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.983650] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.984384] hub 1-1:1.0: USB hub found
[ 1.984478] hub 1-1:1.0: 5 ports detected
[ 2.303422] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.433718] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.433733] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.436529] smsc95xx v1.0.5
[ 2.526730] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a4:85:36
[ 2.623406] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 2.754166] usb 1-1.3: New USB device found, idVendor=2357, idProduct=0109
[ 2.754180] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.754187] usb 1-1.3: Product: 802.11n NIC
[ 2.754193] usb 1-1.3: Manufacturer: Realtek
[ 2.754199] usb 1-1.3: SerialNumber: 00e04c000001
[ 3.386008] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 3.386323] systemd[1]: Detected architecture ‘arm’.
[ 3.435350] NET: Registered protocol family 10
[ 3.436769] systemd[1]: Inserted module ‘ipv6’
[ 3.445137] systemd[1]: Set hostname to .
[ 3.523391] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 3.665083] usb 1-1.5: New USB device found, idVendor=174c, idProduct=55aa
[ 3.665096] usb 1-1.5: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 3.665104] usb 1-1.5: Product: ASMT1153e
[ 3.665110] usb 1-1.5: Manufacturer: asmedia
[ 3.665117] usb 1-1.5: SerialNumber: 12345678928A
[ 3.665914] usb 1-1.5: The driver for the USB controller dwc_otg_hcd does not support scatter-gather which is
[ 3.665924] usb 1-1.5: required by the UAS driver. Please try an other USB controller if you wish to use UAS.
[ 3.665933] usb-storage 1-1.5:1.0: USB Mass Storage device detected
[ 3.676633] usb-storage 1-1.5:1.0: Quirks match for vid 174c pid 55aa: 400000
[ 3.676777] scsi host0: usb-storage 1-1.5:1.0
[ 3.683495] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.683751] systemd[1]: Found ordering cycle on basic.target/start
[ 3.683766] systemd[1]: Found dependency on sysinit.target/start
[ 3.683780] systemd[1]: Found dependency on kbd.service/start
[ 3.683792] systemd[1]: Found dependency on remote-fs.target/start
[ 3.683803] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 3.918562] fuse init (API version 7.26)
[ 4.245193] systemd-udevd[215]: starting version 215
[ 4.724434] scsi 0:0:0:0: Direct-Access asmedia ASMT1153e 0 PQ: 0 ANSI: 6
[ 4.727748] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 4.731788] sd 0:0:0:0: [sda] Write Protect is off
[ 4.731807] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 4.732430] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 4.875100] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 5.346570] usbcore: registered new interface driver uas
[ 5.621244] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.896583] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 5.896777] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.345424] systemd-journald[188]: Received request to flush runtime journal from PID 1
[ 6.790309] 8192eu: loading out-of-tree module taints kernel.
[ 6.795224] 8192eu: Unknown symbol file_path_bs (err 0)
[ 6.851114] 8192eu: Unknown symbol file_path_bs (err 0)
[ 8.421297] sda: sda1
[ 8.429767] sd 0:0:0:0: [sda] Attached SCSI disk
[ 16.397893] Console: switching to colour dummy device 80x30
[ 41.106034] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 56.250082] random: crng init done
[ 65.693466] usb 1-1.3: USB disconnect, device number 4
[ 68.033442] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[ 68.164416] usb 1-1.3: New USB device found, idVendor=2357, idProduct=0109
[ 68.164439] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 68.164450] usb 1-1.3: Product: 802.11n NIC
[ 68.164461] usb 1-1.3: Manufacturer: Realtek
[ 68.164472] usb 1-1.3: SerialNumber: 00e04c000001
[ 68.191578] 8192eu: Unknown symbol file_path_bs (err 0)
[ 68.235273] 8192eu: Unknown symbol file_path_bs (err 0)
[ 1507.777466] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 1507.908658] usb 1-1.2: New USB device found, idVendor=2717, idProduct=0360
[ 1507.908682] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1507.908693] usb 1-1.2: Product: MI 4W
[ 1507.908703] usb 1-1.2: Manufacturer: Xiaomi
[ 1507.908713] usb 1-1.2: SerialNumber: d06001d
[ 1507.911380] usb-storage 1-1.2:1.1: USB Mass Storage device detected
[ 1507.913804] scsi host1: usb-storage 1-1.2:1.1
[ 1518.237512] usb 1-1.2: USB disconnect, device number 7
[ 1518.547456] usb 1-1.2: new high-speed USB device number 8 using dwc_otg
[ 1518.678380] usb 1-1.2: New USB device found, idVendor=2717, idProduct=0380
[ 1518.678395] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1518.678402] usb 1-1.2: Product: MI 4W
[ 1518.678409] usb 1-1.2: Manufacturer: Xiaomi
[ 1518.678415] usb 1-1.2: SerialNumber: d06001d
[ 1518.696943] usbcore: registered new interface driver cdc_ether
[ 1518.707640] rndis_host 1-1.2:1.0 usb0: register ‘rndis_host’ at usb-3f980000.usb-1.2, RNDIS device, c2:41:2d:28:c6:14
[ 1518.707852] usbcore: registered new interface driver rndis_host
[ 1518.731789] 8021q: 802.1Q VLAN Support v1.8
That doesn’t look like a MediaTek adapter to me at all, but rather a RealTek one.
Are you sure it’s a MediaTek adapter? I don’t think this is related to the original post.
That would explain why the kernel has given you no change.
Tp link
which is in line with the info given in post #4
It’s a Realtek.
Yes, that’s not a MediaTek device, so the kernel I posted won’t help.
@fzinken says that the above fix has resolved things for him.
That’s your problem
I’ll take a stab at it but it should be discussed in a new thread.
Can you try:
wget "https://www.dropbox.com/s/pvepk50no24t17x/rbp2-kernel-mk2.deb?dl=1" -O kernel.deb
sudo dpkg -i kernel.deb
sudo reboot
And post dmesg if still not working
