Hey there,
I fail to install the RPi.GPIO on my RPi 1 Rev. B with the latest OSMC.
I’ll do this steps:
- sudo apt-get update
- sudo apt-get install python-setuptools
- sudo apt-get install python-pip
- sudo pip install wheel
- sudo pip install rpi.gpio
But I’ll get the following errors…
Blockquote
osmc@osmc_kueche:~$ sudo pip install rpi.gpio
Collecting rpi.gpio
Using cached https://files.pythonhosted.org/packages/af/2f/407b6e4cc8a0bdf434825a160bba1807991886b63cce16a5f1a6e1f24cdf/RPi.GPIO-0.6.5.tar.gz
Building wheels for collected packages: rpi.gpio
Running setup.py bdist_wheel for rpi.gpio … error
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-4kYVmB/rpi.gpio/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmp2hiNospip-wheel- --python-tag cp27:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv6l-2.7
creating build/lib.linux-armv6l-2.7/RPi
copying RPi/init.py → build/lib.linux-armv6l-2.7/RPi
creating build/lib.linux-armv6l-2.7/RPi/GPIO
copying RPi/GPIO/init.py → build/lib.linux-armv6l-2.7/RPi/GPIO
running build_ext
building ‘RPi._GPIO’ extension
creating build/temp.linux-armv6l-2.7
creating build/temp.linux-armv6l-2.7/source
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-Ub3vap/python2.7-2.7.13=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c source/py_gpio.c -o build/temp.linux-armv6l-2.7/source/py_gpio.o
unable to execute ‘arm-linux-gnueabihf-gcc’: No such file or directory
error: command ‘arm-linux-gnueabihf-gcc’ failed with exit status 1
Failed building wheel for rpi.gpio
Running setup.py clean for rpi.gpio
Failed to build rpi.gpio
Installing collected packages: rpi.gpio
Running setup.py install for rpi.gpio … error
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-4kYVmB/rpi.gpio/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-j_TW7_-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running build_ext
Command “/usr/bin/python -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-4kYVmB/rpi.gpio/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-j_TW7_-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-4kYVmB/rpi.gpio/
What went wrong??`
