I am using windows 10 to attempt to install OSMC to an SD card. I intend to use on rasberry pi. The options I select are English > Rasberry Pi > version 2015.09-1 > on SD card> wireless connection> WPA>WPA2>My SSID>My Password>Select Proper SD drive> accept license> Then it asks me to re-download image file. If I pick yes I get the error “Download Failed! Please Check your network connection.” If I pick no it asks me do I want to extract again. If I pick yes it says “An error occured extracting the archieve! Please consult the logfile.” If I pick no it jumps to congratulations your ready for show time. But nothing is on the sd drive.
I deleted and reinstalled the installer twice. I have ran thru all the options numerous times. Same result.
Look in C:\users<youtusername> for a file named log.txt and post its contents. Also delete any files beginning with osmc from that directory and then try running the installer again
