I am attempting to install OSMC for a Raspberry Pi 2 using the OSMC Installer on Linux (running Debian + KDE). Everything goes fine right up until the installer attempts to remount the SD drive to write the preseed.cfg file, at which point the UI claims it cannot mount the card and must exit. Here is a log file for that attempt: http://paste.osmc.io/utopugodoh.pas
I’ve seen several other posts on the support forum about this, but haven’t been able to acheive a resolution. Here are answers to questions I’ve seen asked in the past:
- Yes, I’m running the installer as sudo
- Yes, I am able to manually mount the SD card
- Yes, /tmp/osmc_mnt/ is being created
- Yes, I have tried multiple SD cards
- No, I haven’t tried a different card reader (I only have the on this laptop)
- No, I haven’t tried the installer in Windows (this laptop is not dual boot)
- No other application is trying to mount the SD card (more on that in a moment)
- The SD card appears to have all the expected files except the preseed.cfg file
When I turn on the Pi, I get the rainbow colored square with no further activity.
Here’s some other interesting notes. I also have an Pi 1. When creating an OSMC image for that, I get the same mount error at the end. However, unlike the Pi 2 image, it boots fine in the Pi 1, but does require me to manually configure the wireless network. FWIW, inserting the Pi 1 SD into the Pi 2 just displays a black screen. Here’s a log file from the Pi 1 install: http://paste.osmc.io/owebemiruf.pas
An additional note, KDE does have an auto-mount feature, but it is off. There is a little notifier widget that gets REALLY excited right around when the installer tries to remount. It’s like the available devices is being refreshed a bunch and the notifier is just letting me know that, yes, that SD card is there for mounting. But it doesn’t appear to actually mount it at anytime.
Other than trying a new SD reader (which requires money I’d rather not spend, as the reader seems to work fine) what other approaches should I try? Is there something I can do manually to the SD card after the installer exits to get it into a working state?
Thanks for whatever help you can provide!
