since last update the autostart of two of my python tools seems broken.
it says “Failed to start /etc/rc.local”
the script worked fine until last update.
also there ist a strange message in “dmesg”
[ 3.461625] systemd[1]: Job plymouth-log.service/start deleted to break ordering cycle starting with basic.target/start
I don’t think it’s updates that have caused your problem.
Spot the error:
May 08 22:01:55 B2RASP2 rc.local[249]: Traceback (most recent call last):
May 08 22:01:55 B2RASP2 rc.local[249]: File "/home/osmc/CouchPotatoServer/CouchPotato.py", line 131, in <module>
May 08 22:01:55 B2RASP2 rc.local[249]: l = Loader()
May 08 22:01:55 B2RASP2 rc.local[249]: File "/home/osmc/CouchPotatoServer/CouchPotato.py", line 40, in __init__
May 08 22:01:55 B2RASP2 rc.local[249]: settings.setFile(self.options.config_file)
May 08 22:01:55 B2RASP2 rc.local[249]: File "/home/osmc/CouchPotatoServer/couchpotato/core/settings.py", line 66, in setFile
May 08 22:01:55 B2RASP2 rc.local[249]: self.p.read(config_file)
May 08 22:01:55 B2RASP2 rc.local[249]: File "/usr/lib/python2.7/ConfigParser.py", line 305, in read
May 08 22:01:55 B2RASP2 rc.local[249]: self._read(fp, filename)
May 08 22:01:55 B2RASP2 rc.local[249]: File "/usr/lib/python2.7/ConfigParser.py", line 546, in _read
May 08 22:01:55 B2RASP2 rc.local[249]: raise e
May 08 22:01:55 B2RASP2 rc.local[249]: ParsingError: File contains parsing errors: /root/.couchpotato/settings.conf
May 08 22:01:55 B2RASP2 rc.local[249]: [line 538]: 'passwor'
May 08 22:01:55 B2RASP2 rc.local[249]: ConfigParser.ParsingError: File contains parsing errors: /root/.couchpotato/settings.conf
May 08 22:01:55 B2RASP2 sudo[469]: pam_unix(sudo:session): session closed for user root
May 08 22:01:55 B2RASP2 systemd[1]: rc-local.service: control process exited, code=exited status=1
hmmm … that is not possible. it works with manual startup. also this does not explain why the other python app (sickbeard) does not start up automatically.
The error is there in black and white, it is clearly causing the Python script that you are running from rc.local to crash. Please fix the error in settings.conf and see if it fixes the problem with rc.local.
If you’re starting couchpotato manually from the command line then you are running it under the osmc user account. Any commands you run in /etc/rc.local are running as root.
If you need to run a command in rc.local under the osmc user account you need to use sudo, like so:
