Hi all,
I’m a newbie to RPi, Linux and OSMC and need some help to install OSMC !
Here what I want to do : install OSMC on my RPi3 to get a homemade multimedia server and then install Nextcloud on OSMC to get a home cloud in the same time. As I’ve read that SD Cards don’t last very long I’d like to install OSMC filesystem on a USB stick.
I bought a 4TB USB Stick (Seagate BarraCuda) and have formated it in GPT with 2 ext4 partitions (20G dedicated to the OS and Nextcloud and 3.6T dedicated to my media files). My SD Card is a 16Gb class 10 included with the RPi pack I bought.
After many many hours failing at doing this and seeking answers in many forums I request here your help !
What I did :
- installed first raspbian and formated my USB stick as mentioned above
- formated my SD Card with SD Card Formatter on Windows
- downloaded the OSMC installer for Windows
- Ran the install program, chose the install on USB stick and wireless connection. Everything seems ok here.
- Boot the SD Card on my Pi, everything seems ok since I get that message on the screen : “Install failed : can’t mount root”
Here is the install.log :
Thu Jan 1 00:00:07 1970 Starting OSMC installer
Thu Jan 1 00:00:14 1970 Detecting device we are running on
Thu Jan 1 00:00:14 1970 Mounting boot filesystem
Thu Jan 1 00:00:14 1970 Trying to mount to MNT_BOOT (/mnt/boot)
Thu Jan 1 00:00:14 1970 Using device->boot: /dev/mmcblk0p1 and FS: fat32
Thu Jan 1 00:00:14 1970 Preseed file found, will attempt to parse
Thu Jan 1 00:00:14 1970 Found a definition for storage: usb
Thu Jan 1 00:01:21 1970 Creating root partition
Thu Jan 1 00:01:21 1970 From a root partition of /dev/sda1, I have deduced a base device of /dev/sda
Thu Jan 1 00:01:21 1970 Must mklabel as root fs is on another device
Thu Jan 1 00:01:21 1970 Going to mklabel with device: /dev/sda with a label type of MSDOS
Thu Jan 1 00:01:22 1970 Calling mkpart for device: /dev/sda and fs: ext4 with start 4096s and end 100%
Thu Jan 1 00:01:23 1970 Calling fmtpart for partition /dev/sda1 and fstype ext4
Thu Jan 1 00:01:23 1970 Mounting root
Thu Jan 1 00:01:23 1970 Trying to mount to MNT_ROOT (/mnt/root)
Thu Jan 1 00:01:23 1970 Using device->root: /dev/sda1
Thu Jan 1 00:01:23 1970 Error occured trying to mount root of /dev/sda1
Thu Jan 1 00:01:23 1970 Halting Install. Error message was: can’t mount root
I tried this several times with the same result. I also tried to install OSMC with Noobs but then it doesn’t give me the opportunity to install the system on my USB stick.
Any idea of what’s happening ?
Many thanks to the ones who can help me !
Arnaud
