Vero4k failing to start up
When I turn power on I get a purple screen
Then the Blue OSMC starts up then everting dies
No red lights on the box after the blue osmc screen
Any idea?
Any idea?
If possible try a different powersupply or powering off an A to A usb cable.
Or you try a reinstall:
Thanks Tom.
The adapter I have is
tzh 503
5v 2a
The original that can with it
Looking on the vero site there power supply is
5v-2.5a
Stick with what I’ve got or go for the 2.5a?
Been working fine for 2 year
Either or, I think the 2.5a is for the vero4k+, as this draws slightly more power; but will work fine on the vero4k.
But if you need to purchase a psu or a cable to test, I would try a reinstall first.
@Boxster74 Sorry didn’t even look in the store, please ignore the strike through above and try a reinstall.
Thanks Tom.
The 5V 2.5A power supply is for Raspberry Pi, not Vero.
To me it just sounds like @Boxster74 just needs to reinstall OSMC.
Cheers Sam I’ll give it a try in the morning
Tried reinstalling as suggested.
Power on
Blue Osmc screen appears
Then powers down
Doesn’t have a chance to search for usb before shutting down
There is still power going to the vero as there is a light on the usb? But after the osmc start up page it just sits on a blank blue screen
Are you able to try the reinstall with a microsd card?
Thanks Tom.
Some photos would help us
Also a screenshot of the contents of your SD / USB so we can verify that you imaged it correctly.
