I have an issue with a brand new Vero 2 that has the same symptoms as described by Giubeca in this thread.
I powered it up OK last night, went through the usual configuration steps (WiFi, etc) and updated it via My OSMC. After installation of the update, it failed to boot with:
Waiting for root filesystem device /dev/vero-nand/root
displayed on the attached HDMI television. After some seconds, it also displayed:
FATAL ERROR: Could not find root filesystem /dev/vero-nand/root - if this is a USB install please check the USB drive is connected.
OSMC init ramfs Rescue Console
For help and support see http://osmc.tv/help
I used the OSMC installer to generate a reinstallation SD card using a Kingston 32 GB card, placed the card into the Vero 2 and connected power. The Vero didnāt recognise the card and failed with the same messages about being unable to find the root filesystem.
I tried again today using two different Sandisk 8 GB cards with the same result. On checking the cards after each attempt to boot, I found that they still contained the two files filesystem.tar.xz and kernel.img, which I understand means that the Vero didnāt recognise the presence of the cards.
So Iāve now tried three SD cards and the Vero ignores them. Iād welcome suggestions on how to proceed. Is there a way of installing from USB or the network?
