I have searched using all the key words I can think of and have found similar questions but they all seem to have the answer of ‘use the scroll bar’
My question is, is it possible to speed up the scrolling of lists when using the scroll bar?
I have well over 1000 movies on my NAS and scrolling one page at a time takes ages.
I know I can filter and search, but that can be cumbersome using the on-screen keyboard.
Thanks Yvan but I can’t get that to work.
When I press right arrow key on my remote it does the same as pressing left (i.e. brings up the options where you select filter, list type etc).
I should mention, I am running OSMC December update on a RPI 3B.
On my system I just hold down page down key on keyboard; then it roll quickly page by page and indicates A, B, C when I enter these areas. I have 7000+ movies in my library (grouping on)
Hi everyone thanks for replies so far.
I don’t have a keyboard connected and use my amp (Yamaha) remote via HDMI CEC as my Samsung tv does not have CEC. I’m not sure how to set different remote keys to different shortcuts but will look into it.
As @tanakaP said, on a remote that is directly connected to the device running Kodi, you can use the number keys to do SMS code, so 2 = ABC, 3 = DEF, etc. I don’t know if this works with a CEC remote, but you can try.
Actually my Raspberry Pi is connected to a Yamaha amp and also my Sony TV and I’m using the TV remote to control Kodi. I don’t remember if I had to enable some extra option on the amp but CEC is working as if the Pi was directly connected to the TV. I can also control Kodi from an openhab installation with the Kodi binding and, through the openhab skill (with virtual switches, rules and routines), via voice commands on Alexa.
