All of a sudden when I wanted to watch something I see a sad smiley and something seems to be looping.
When looking in the log file I see this:
19:29:23.708 T:4109415360 ERROR: AML: no rw on /sys/class/ppmgr/ppmgr_3d_mode
19:29:23.735 T:4109415360 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic
19:29:23.908 T:4109415360 ERROR: EGL error in InitDisplay: 3001
19:29:23.908 T:4109415360 ERROR: InitWindowSystem: Could not create display
19:29:23.908 T:4109415360 FATAL: CApplication::Create: Unable to init windowing system
What can this be? How can I fix it asap because I can’t watch my movies/series now.
btw I didn’t update to the latest version yet and I disabled auto updating.
I’m mobile so haven’t looked at the logs, but you’ve probably installed Hyperion and brought in MESA libraries. This will stop the display from working correctly.
This was discussed recently so a search for MESA in the Vero section will help
Thanks all for your quick response! Excellent support!
Now I’m going back to trying Hyperion :).
Hopefully @penfold42 will reply in the other topic soon.
Thanks again!
[edit] Hmmmm. Seems removing that mesa breaks my Hyperion.ng installation.
I get this “bin/hyperiond: error while loading shared libraries: libQt5Gui.so.5: cannot open shared object file: No such file or directory”.
how did you remove the mesa bits?
if you used dpkg to do it it might have helpfully uninstalled some of the Qt5 packages too.
The weird thing on my system is I cant find how I fixed it…
My pi3 with OSMC is my primary dev system for hyperion so it definitely needed it resolved - even with a quick hack!
I remember hacking the mediacenter script at one point to force the library search path but it looks like its now the default.
I wonder if the installation order is important for how the library search path ends up. It will have been months since qt5 was installed, but OSMC get updated monthly
I removed it with: sudo apt-get remove --purge libegl1-mesa
So do you have an idea how I can get Hyperion.ng working again without breaking OSMC working?
Which commands to I need to run?
Ok I can do that but is there an easy way of making a backup (image) first? Or how can I quickly revert back in case I want to see a movie/serie whilst kodi is not working?
Is that by just running: sudo apt-get remove --purge libegl1-mesa you think?
I can then just repeat the steps again when you (or Sam) have another new thing to test out.
