Hi. I think I have a faulty remote control for my Vero 4K. The OK button and the cursor buttons work but no other button does anything. I tried unplugging the Vero and also changing the battery. I tried pairing but pressing Home and OK for 5 seconds doesn’t give a flashing light. If I press the other buttons The blue led does flash.
Is the remote faulty?
Thanks for the help.
reproduce the issue
I had to use my Logitech Harmony remote to navigate. Only the cursor keys and OK button work on the Vero remote.
The kodi remote app on my iPhone works fine as well.
One other thing I forgot to mention. I tried the key map add on and the keys didn’t seem to register when I pressed them.
@sam_nazarko @Tom_Doyle Any luck reviewing the logs? Thanks
Looks like you need a new dongle.
Ping support@osmc.tv with your order number and we will ship you a replacement.
Thanks. I have done this.
