I am not sure how this happend but I had ffmpeg working normally on my Raspberry PI 4 with OSMC and for some reason it stopped working saying that libGL.so.1 is missing. I understand that this lib is provided by libgl1 package however this I cannot install since it is conflicting with rbp2-mesa-osmc.
How can I have ffmpeg running on my system?
Alternatively, can I uninstall rbp2* and rbp4* packages install libGL1 and thern reinstall rbp* stuff?
That’s because we were accidentally providing libglapi-mesa in OSMC, when we shouldn’t have been doing so as we provide our own implementation downstream.
Run the following command to add the staging repository: echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
Now run:
sudo apt-get install libglapi-mesa
You may also need to reinstall ffmpeg.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command: sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Thank you. It solved my problems and I got ffmpeg running. I am astonished how quickly you responded.
Regarding compiling ffmpeg - after failing to solve my issues with installing various packages and looking for missing libs I did tried to compile it. I started with libraries but it took so long I thought why not give the osmc forums a chance. Your response was so fast I didn’t even manage to face any problems with compilation. Thanks again!
