I’m trying to transfer some videos (about 100) to the sd card of my Pi3.
All transferred are made into sub folders of the main video folder.
After a while, I can not transfer files anymore. I have to remove files from the sd card and then it works again.
The sdcard is 32go and so far I have the equivalent of 12go on the sd card.
The sdcard is correctly formatted (osmc fresh new installation)
Here is hte message on FileZilla
Erreur : error while writing: received failure with description ‘Failure’
the kody log only shows one identical message:
ERROR: CecLogMessage - could not open a connection (try 5)
08:37:25.014 T:1806201840 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
08:37:25.014 T:1806201840 ERROR: CecLogMessage - Open - vc_cec could not be initialised
08:37:25.018 T:1806201840 ERROR: CecLogMessage - could not open a connection (try 6)
08:37:26.014 T:1806201840 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
08:37:26.014 T:1806201840 ERROR: CecLogMessage - Open - vc_cec could not be initialised
08:37:26.015 T:1806201840 ERROR: CecLogMessage - could not open a connection (try 7)
08:37:27.015 T:1806201840 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
08:37:27.015 T:1806201840 ERROR: CecLogMessage - Open - vc_cec could not be initialised
08:37:27.015 T:1806201840 ERROR: CecLogMessage - could not open a connection (try 8)
08:37:28.016 T:1806201840 ERROR: CecLogMessage - Regis…
Alternatively you may want to do a low level test on the SD card. But as that would delete the contents of the SD card you might first want to do a backup.
that s also what I thought…this is the third card I get a proble with. The two first ones wouldn’t allow me to install OSMC (bought from internet). This one comes from a IT shop down town…
du -h seems to be the command to use.
the osmc folder is taking 13g (mainly my videos)
the mmcbk0p2 contains another folder that takes 16g, I can not find the folder…
fzingen, thanks for trying to help.
when I run du -h / , I get the following at the bottom of the analysis “14G”
It would be very surprised to have another fake card. It’s a brand new Sandisk 32Go card in a genuine packaging bought in the IT dpt of a big supermarket…no amazon or ebay sourcing…
This is what I’m about to do.
I’m just trying, at the moment, to find out how to make a full back up of the sdcard on my pc where Putty is running…
trying with Win32Diskmanager and I will then launch the hw2test program (it will format my sdcard from what I’ve seen after installing it.)
to acces your “/” in windows you can use this program
It will allow you to read from the SD card so you can make a back up on your pc. Or you can use a program like Win32DiskImager to make an image file of your SD card.
Backup has been done without any issue.
I’ve then formated the sd card (NTFS - 32Go) and run H2testw, result is as follow :
Warning: Only 30343 of 30433 MByte tested.
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 12.7 MByte/s
Reading speed: 15.4 MByte/s
H2testw v1.4
No idea what’s happening ! the card seems to be OK.
I will run the installation again and run a big file transfer to see what happens
