I paired my Fire TV Stick Remote, it works pretty well, except for the Home- and the Select- (Enter?) Button. They show no function at all. Is there a way to fix this ?
Are you running the latest updates ?
The Fire TV stick remote should work fine, I have tested it personally with mine. The home button should take you back to the Kodi home screen, while the select button button will work as an OK button.
Are you sure you don’t have a custom remote.xml that is messing things up ?
