Hello,
I just received my Vero 4K hoping it will solve all my problems with RP3.
Added library over SMB share and played two movies that have DTS HD-MA.
I tried the stock version and No HD-MA on receiver. Went to settings and enabled passthrough, still no HD-MA changed from PCM to HDMI still no passthrough.
Enabled DTS HD then the sound is muted when passthorugh is enabled.
Then updated to the latest version and rebooted.
Once booted the system crashed and had to make a hard reboot via power.
When playing the DTS HD-MA file again it says Multi-CH PCM in the display.
when the file is playing and i go to sound settings via popup screen and disable passthrough the display still shows the same on the reciever: Multi-CH PCM
went to settings in system and changed:
Output Configuration: Best matched
Resample quality: High
then a high crackeing sound began in the rear speakers.
a DTS movie works but not DTS HD-MA for now.
Switched on and off in the popup meny for passthrough and Boom! DTS HA-MA works
Same on another move.
I have to get into the popupmenu and disable then enable Passthrough then HD-MA works!
Is this a kind of bug or do i have wrong setting somewhere? lol
Well i at least got it to work.
thanks in advance.
EDIT001: when pauseing the movie for some seconds the sound is dissapearing aswell,
enable and disable passthrough fast makes the unit it hang itself and you have to make a power reboot.
EDIT002: Crackeing:
Workaround: I disabled the GUI sound since the system is getting crackeing sound when going from the HD-MA sound to menu and the gui sound and now works better.
EDIT003: When trying to enable the DTS HD-MA sound as per solution above via popup meny the system have now hanged two times in w row, event if i wait 10 seconds for each action.
