Fix minor typo within advancedsettings.xml
Currently in OSMC Decemberr 2021 release, the default /usr/share/kodi/system/advancedsettings.xml contains a minor typo reported by kodi.log
2021-12-27 12:53:56.017 T:7722  WARNING <CSettingsManager>: missing version attribute
And indeed it should read
<advancedsettings version="1.0">
to avoid this warning.
Regards, Michael
Hopefully the issue is now addressed with the following commit:
  1. Login via the command line
  2. Run the following command to add the staging repository:
    echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
  3. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  4. Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
I’d also recommend you deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Thanks for working on that typo. But it is not fixed. I followed your instructions, no error messages, but /usr/share/kodi/system/advancedsettings.xml was not updated - it’s still from 2021-12-21.
Even worse: Neither IR nor bluetooth now work. I’m unable to register rc6 protocol by ir-keytable -p rc-6.
rc_core: Loaded IR protocol module ir-rc6-decoder, but protocol rc-6 still not available
And my harmony hub cannot connect any more (but that might be an independant issue) using bluetooth
Bluetooth: hci0: command 0x0408 tx timeout
The only available protocol is lirc. I can add mce_kbd, but not rc-6.
Did that update change something else? Howto revert?
Regards, Michael
Rebooting a second time did resolve my bluetooth problem.
But my IR problem is still there.
dmesg tells me:
[   17.536962] rc_core: Loaded IR protocol module ir-rc6-decoder, but protocol rc-6 still not available
[   59.823012] rc rc0: two consecutive events of type space
Your suggested fix did not provide a new kernel - thus I’ve no idea why rc-6 now is failing.
Regards, Michael
Additional info: Regarding bluetooth I do believe that due to bad placement of my harmony on top of a metal case its signal is partly absorbed - It’s now lifted a little bit improving RSSI value from -24 to -14.
Don’t know if related to your changes - I see the following error messages from systemctl start mediacenter:
Dez 30 10:16:14 imurr9 mediacenter[683]: Mesa warning: failed to remap glEGLImageTargetTexStorageEXT
Dez 30 10:16:14 imurr9 mediacenter[683]: Mesa warning: failed to remap glEGLImageTargetTextureStorageEXT
Dez 30 10:16:14 imurr9 mediacenter[683]: Mesa warning: failed to remap glCopyImageSubDataNV
Dez 30 10:16:14 imurr9 mediacenter[683]: Mesa warning: failed to remap glViewportSwizzleNV
Dez 30 10:16:14 imurr9 mediacenter[683]: Mesa warning: failed to remap glAlphaToCoverageDitherControlNV
Dez 30 10:16:14 imurr9 mediacenter[683]: Mesa warning: failed to remap glInternalBufferSubDataCopyMESA
Dez 30 10:16:33 imurr9 sudo[782]:     osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/mv /var/tmp/config-user.txt /boot/config-user.txt
Dez 30 10:16:33 imurr9 sudo[782]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dez 30 10:16:33 imurr9 mediacenter[683]: mv: der Eigentümer für '/boot/config-user.txt' konnte nicht beibehalten werden: Die Operation ist nicht erlaubt
Dez 30 10:16:33 imurr9 sudo[782]: pam_unix(sudo:session): session closed for user root
There seems to be an owner problem for /boot/config-user.txt. Currently it is root/root
-rwxr-xr-x 1 root root 85 Dez 30 10:16 /boot/config-user.txt
and it is touched when kodi/OSMC is started.
Regards, Michael
/boot/ is a vfat filesystem so it doesn’t support permissions/owner. The owner of it comes from the mounting time. It was always owned by root/root.
Therefore the error message always was there because the user can not be remained after the mv command as no users are supported on vfat.
Thanks fzinken for that clarification.
Coming back to my original problem. Now I have an idea what might be the reason for my new IR problem. My IR signals are grabbed directly by lirc protocol within ir-keytable. And I’m unable to switch back to rc-6. Each IR keypress is sent towards kodi and (from kodi perspective correctly) executed. Thus I guess that as an unwanted sideeffect of your testrelease the original IR handling has changed. Despite being disabled eventlircd is running. I could stop it, but still can’t enable rc-6.
Is that an intended new behaviour?
Regards, Michael
Please post some logs, as it seems like you didn’t update your device.
No changes to IR in staging repo.
Thanks for your patience - I repeated your steps:
sudo bash
apt-get update
shutdown -r now
with minor modifications. Sadly no changes: advancedsettings.xml is unchanged, I’m still unable to engage rc-6:
ir-keytable -p rc-6
Protocols changed to rc-6
but kernel reports
[  275.898783] rc_core: Loaded IR protocol module ir-rc6-decoder, but protocol rc-6 still not available
[  478.169856] rc_core: Loaded IR protocol module ir-rc6-decoder, but protocol rc-6 still not available
I’ve validated contents of /etc/apt/sources.list.d/osmc-devel.list to be
Both update and dist-upgrade run without error message, dist-upgrade did fetch something.
See here the last entries from apt log /var/log/apt/term.log partly reduced manually
Log started: 2021-12-30  07:40:48
(Lese Datenbank ...
(Lese Datenbank ... 5%
(Lese Datenbank ... 100%
(Lese Datenbank ... 46261 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../mediacenter-skin-osmc_19.1.2-1_all.deb ...
Entpacken von mediacenter-skin-osmc (19.1.2-1) über (19.1.1-8) ...
mediacenter-skin-osmc (19.1.2-1) wird eingerichtet ...
Log ended: 2021-12-30  07:40:52
Log started: 2021-12-30  15:31:40
(Lese Datenbank ...
Vorbereitung zum Entpacken von .../mediacenter-skin-osmc_19.1.2-2_all.deb ...
Entpacken von mediacenter-skin-osmc (19.1.2-2) über (19.1.2-1) ...
mediacenter-skin-osmc (19.1.2-2) wird eingerichtet ...
Log ended: 2021-12-30  15:31:43
Maybe I don’t see a change because I use the standard kodi skin?
But I also must admit that till today morning I did not reboot my raspi to test if my setup ā€œsurvivesā€ reboot. Thus maybe my new IR trouble is not related with the update?
I have discovered one flaw within my setup - to disable eventlircd one has to mask it by
systemctl mask eventlircd
Anyhow, I don’t see your change within the global advancedsettings.xml.
Sorry, Michael
Apologies – I can see the issue (forgot to bump package version).
It will be in the next update.
Thanks.
And I start to understand why rc6 is failing - the corresponding kernel module is no longer loaded. I can enforce rc6 by
insmod /lib/modules/5.10.78-2-osmc/kernel/drivers/media/rc/ir-rc6-decoder.ko
ir-keytable -c -p rc-6 -w /usr/lib/udev/rc_keymaps/rc6_mce.toml
and dmesg is happy to report
[  866.139072] IR RC6 protocol handler initialized
I also have discovered the file /etc/modprobe.d/blacklist-rc6.conf containing
blacklist ir_rc6_decoder
Thus no wonder that it is not loaded. Thus I’ll delete that file and reboot - fingers crossed. WORKING!!!
Hopefully this long discussion might be usefull to others also suffering under my problem.
Regards, Michael
Just found this issue, and the answer, in case anyone finds themselves here:
The blacklist file is created by the checkbox on the left side of the OSMC remote controle setup, it says something like ā€˜Disable RC6 Remote…’ (the text is truncated on my machine).
I Unchecked this, the file was removed, I rebooted, selected the RC6 MCE control, and it worked.
