Hello guys,
I have update my vero in 19.X
I have just received my Vero4K+ and i have a perpetual crash loop as soon as i enter one of my saga.
I have already tried
sudo apt-get update
sudo apt-get dist-upgrade
there is my log : https://paste.osmc.tv/iqicepovih
thanks for your help
What do you mean with enter you mean try to play?
Can you indicate which saga as it makes it easier to find it in the logs.
Also I see you use a central MYSQL server but I can not see sources configured. So how are the path in the Database for reaching the NAS?
no rigth after i expand the saga…
Edit : I have rebuild my entire database and now it doesn’t crash.
I guess all the database migration since 17.X have broken it…
sorry for the inconvenience
