Hello,
When I try to put in a fixed IP then the ATV1 stops connecting to the Ethernet.
Only had luck with DHCP
It’s so I don’t have to keep reconfiguring web remote on iPad or Web Browser etc.
Hello,
Are you certain that you are not trying to set an IP that is already being used by another device? Are you certain that the IP you are trying to set is appropriately within your subnet?
I shall do an idiot check
Please explain what IP DHCP has handed the device and the IP that you wish to now set for it.
Gateway 192:168:0:1
Most DHCP devices 192:168:0:2 to 192:168:10
At the moment it DHCP’s to 192:168:0:2
If I change it to manual with the same IP and…
It is now working
Ohhhh Dear. What a Donut. Should have tried again before posting. Not sure why it gave me hassle before.
Thanks for helping anyway.
Enjoy.
If your set up is typical then you’ll have a gateway at 192.168.0.1 and a subnet mask of 255.255.255.0
The subnet mask defines which part of an IP address relates to the network and which part relates to the host.
https://en.wikipedia.org/wiki/Subnetwork
So 255.255.255.0, defines that 192.168.0 is the network address and hosts on that network can take addresses from 192.168.0.1 to 192.168.0.255
From your second post I assume you tried an address of 192.168.1.something
As this address isn’t in the range recognised as being on your network, you device wouldn’t be able to connect to the gateway.
One thing to be wary of is if your router is handing out IP addresses using DHCP, then if another device gets given 192.168.0.2 (if it is powered on before your ATV) then this will cause a conflict. Most routers have some form of IP reservation where you can set the IP that will be allocated to a device based on it’s MAC address. Login into your router at 192.168.0.1 and have a look at the settings available. Probably safer to do the address allocation this way.
I think that was a typo where op simply omitted a zero.
Absolutely correct. I used 192:168:1:3 thinking it would be well out of reach. Too out of reach…
Just had an IP conflict before typing this when iPhone stole Macbooks sleeping IP.
Thanks for clearing that up. So ATV can be 192:168:0:50 something and never cross another device in my home.
The first three octets must match. That would be the subnet. You can only change the last octet to be some number 2-255.
Managed to keep my knowledge of networking to an absolute minimum
You keep on writing the IP address with colons rather than full stops
192:168:0:1 rather than 192.169.0.1.
As far as I know that is not possible?
That’s just my mistake posing on here. I did it with “.” on the ATV1
