I found this issue from 2016 [FLAC HD audio files don't play]
I have this same issue still on the VeroV. Flac HD (24bit-192k) file seems to play and visualisation (Goom )is also activated. but no sound. I have a HD cable receiver. And same track in ACC is passed trough correctly. On my former kodi setup on a Raspberry these FLAC tracks are no problem for my receiver. I cant remember if it worked out of the box, back then, or it needed some tweaks to get it working. I hope someone here can give me the solution?
reproduce the issue
upload the log set (all configs and logs!) either using the
