First, Got this Vero today… It’s mindblowingly good. The attention to detail is amazing, congratulations to the team.
So i got myself a FLAC test file with a bitrate of 833kbps, stored it on my NAS, and added it to my Vero 4K’s library.
All other test files (including 4k videos, h.265, etc.) played fine without any lag or problem, but the FLAC file had its pitch really up and it is very distorted.
It’s hooked up to a stereo setup… on the HDMI IN port of an Xbox One. (Still testing!)
Can you try connect it to the TV directly?
As an aside: @DBMandrake doesn’t recommend Xbox One’s HDMI-in. Doesn’t handle refresh rate adjustment correctly.
Connected directly to the TV the audio plays fine, all formats…
I’m completely right now! I’ve had lots of stuff connected to the HDMI IN of this Xbox : STB’s, Chromecasts and the aforementioned RPi3, without any problems!
Beware with setting the memorysize to numbers looking like yours. I’ve found out that Kodi 17 likes to write the cache to disk (!) when the number isn’t derived from 1kb = 1024 bytes.
A proper value would be: 94371840 which equals to exactly 90 megabytes.
Should not be related to the number being derived from 1024,
<memorysize>0</memorysize> <!-- number of bytes used for buffering streams in memory
When set to 0 the cache will be written to disk instead of RAM -->
